Ive seen a couple of articles that state that the cam is different to the l76 but they never gave the specs .
Hence why there is a 10kw difference between the 2
Here is a quote from one website
L77 V8 engine
L77 flex fuel capability
The L77 engine had flex-fuel capability whereby it could run on a mixture of petrol and ethanol up to E85 (i.e. 85 per cent ethanol and 15 per cent petrol). Bio-ethanol is derived from sorghum and by-products linked to the agricultural production of wheat and sugar. Although ethanol has a lower energy density than petrol, ethanol has a higher octane rating which enables it to provide greater performance.
L77 changes
Due to the properties of E85, the changes for the L77 engine included: •hardened intake, exhaust and seat valves;
•a new fuel pump;
•a flex-fuel sensor to detect the ethanol level in the fuel line – this detection occurred after each re-fill and continuously while driving; and,
•Recalibration of the PCM.
L77 for manual transmissions
Models with the L77 engine and manual transmissions did not have an active AFM system and had a higher power output due to their different camshaft profile
This is in reference of the difference between the l76 and l77
Here is a Qoute from GM motorsports
GM Motorsport All 3 engines, L76, L77 & L98 are the same size and basicly the same engine - L98 has no DOD internals, L76 has the DOD internals - L77 has DOD internals and can run on E10 fuel - All Holden VE V8's Series 2 onwards manuals & autos have the L77engine.
December 18, 2011 at 2:56am
GM Motorsport The L77 also have a differant cam and makes aprox 10 more rwkw than the other 2
