L77 injectors
Timmaay
VE Commodore SS
Does anyone know the part number of the original injectors fitted to Series 2 VE with L77 E85 capability? Can I use non ethanol compatible ones if I just stick to premium 95? Any advantages to buying OEM over aftermarket ones? Any info appreciated, cheers
07GTS
Australia
VEGTS BUILT BLOWN E85
if u dont want to have to adjust the tune get the same exact injectors that were in there, the e85 ones flow more so going to others will throw all your fueling out the ecu has to know the flow rate (and other perameters) to make it accurate
syked
Donating Member
2011 WM Caprice
Do you have the last 8 digits of the vin?
_R_J_K_
Zenki S14
Are you replacing them for a reason?
Timmaay
VE Commodore SS
Thanks all, I ended up replacing just the 1 (Number 6), fixed my problem. For info, Repco listed an injector that SHOULD fit, for $155.00. Genuine Holden one from the local dealer here was $72.00
VS_Pete
Donating Member
Always good to ask Holden.
Mattricho
VF SSV my15
I agree with @VS_Pete i was looking for a coolant overflow and the cheapest I could find it on eBay was $90 thought fu*k it I’ll ask Holden $30 later I had the new overflow and 1L of coolant.
morale of the story is there’s no harm in asking.
VS_Pete
Donating Member
