L77 lifter removal
Discussion in 'VF Holden Commodore (2013 - 2017)' started by Wayne001, May 5, 2019.
  1. Wayne001
    Wayne001 Member
    Meadow springs
    Vf calais
    Hi all , can the lifters be removed from a L77 with out taking heads off ?
  2. immortality
    immortality Home of the smoky breakfast Bacon! Staff Member
    Sth Auck, NZ
    No. All LSx type engines have to have the heads off to remove the lifters and buckets.
  3. Wayne001
    Wayne001 Member
    Meadow springs
    Vf calais
    Cheers .
  4. Wayne001
    Wayne001 Member
    Meadow springs
    Vf calais
    My engine is stock done 82000klm in a 2013 calais . Are these lifters as bad as i have been reading ?
  5. lmoengnr
    lmoengnr Well-Known Member
    Sunbury Vic.
    MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
    No, not in the L77's.
    The bad reputation came from the original lifters fitted in the L76's.
    Updated, and better lifters were fitted in the L77's.
  6. Wayne001
    Wayne001 Member
    Meadow springs
    Vf calais
    Thanks for that , so they do not need to be replaced at 100000klm ?
  7. lmoengnr
    Sunbury Vic.
    Pretty sure that's not required...
  8. blackve76
    blackve76 Well-Known Member
    there
    VE SS ute 360rwkw N/A, 2016 VF2 SS M6
    Not really but GM put out a service advice thingy years ago recommending replacing at 100k.
  9. vr304
    vr304 Well-Known Member
    Auckland, New Zealand
    2007 ssv manual
    The lifters get noisy if they are going bad, if u don’t have ticking noises (which can be other things too) I wouldn’t be concerned
  10. Wayne001
    Wayne001 Member
    Meadow springs
    Vf calais
    Just a very very slight one when it is warm on the drivers side , will see what happens in the next oil change .
  11. krusing
    krusing Active Member
    Bayside, Melbourne
    I have lifter noise when my L77 is cold, and the noise it softens when its get a bit warm,
    Where I think I found its on pot 4 or 6, got the old Mechanics Stethoscope out, and its noisy around that area.
    I may need to change them, but didn't really want to take the heads off.
    However, it is due for an oil change, as its coming up to hit 150K/m mark this week,
    Will see how it sounds after new oil in it, 5w 30 recommended,
    I heard the filter under the oil sensor [at the rear of the Valley Cover] should be cleaned/replaced at some point, is that correct ?, if so, at what K/M ?,
    if so, probably just as easy to purchase a new one and swap it.
    As per the Ebay
    https://www.ebay.com.au/itm/General-Motors-12585328-LS-AFM-DOD-LIFTER-OIL-FILTER/232909790462?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
