Moredhel84
- Mar 15, 2005
- 26
- 0
- 0
- Age
- 39
- Location
- Brisbane, Australia
- 4.3L VR Berlina, 5spd.
Hi guys,
Been racking my brains the past fortnight trying to work out why my stroked Buick 4.3L VR is only putting out 147RWKW. Now can’t give you exact specs but can tell you what the engine builder told me. Port/polished heads/inlets, reconditioned Bosch injectors, V8 TB, CAI, saloon spec cam, stroked/bored to 4.3L, custom Chip-Torque tune/dyno, extractors and 2x 2¼” exhaust all connected to a 5spd Getrag manual with HD clutch, still got the stocko diff + ratio.
Been in contact with some of the guys at FIT looking at high ratio rockers/lifters thinking maybe that’s where I’m going wrong but they reckon this should not be the problem as the cam and heads have been worked already and the rockers will only add 7RWKW at best. Tony at FIT seems to think its some kind of tuning problem or maybe the cam is out a little.
By all means the car isn’t slow but for the money I spent (close on 12K) I was expecting higher results. Reason for the high pricing due to the fact that this is actually the second rebuilt engine in a month. First got rebuilt by the Brock Shop with no stroker but pretty much everything else. It died in LESS then 1 week, not covered by warranty ($5K gone) as they claim the torque converter played up causing the converter to push the crank back into the engine causing excessive amounts of end-float which ended up eating the engine and the auto. Now every mechanic I’ve spoken to reckons this is a load of crap and if anything it would have been the engine killing the auto not the other way around but as I took it back to their shop as soon as it died, I have no way of proving this as they pulled everything apart before telling me what happened and then told me I need a new engine and gear box. Long story short, took it to my cousin who’s a manager for a Kmart Tyre and Auto and got him to put the 5spd in with HD clutch and send the engine in for another rebuild this time with the stroker crank. BTW the engine builder came back to say that the Brock Shop built the engine to its up most limits, in other words, they were giving me figures of 200FWKW (far from it according to the current graph) with no stroker but when my guys took the engine apart it was a case of quantity over quality with the engine pretty much over-extended and not designed to take as much power as it had.
Sorry about the long rant, but losing that quantity of money for gains I didn’t achieve has gotten me a little bit annoyed. In final if anyone can suggest why or why not I’m getting this power it would be greatly appreciated (attached dyno graph).
Thanks,
BJ
PS. To anyone else considering going to the Brock Shop up in Brisbane, one word for you…don’t. When I rang up the department of fair trading, was informed that they know of them quite well and all the mechanics I’ve spoken to agree, they falsify dyno charts to give higher readings and in the end their work isn’t up to scratch not to mention their customer service is below abysmal.
Thanks,
BJ
