lack of rpm?
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by h0Ld3n`VN, Jul 29, 2008.
  1. h0Ld3n`VN
    h0Ld3n`VN New Member
    NO CAR ATM.. -.-
    whenever im parked on D the idle goes allmost 400rpm?
    especially when im driving and stopping at the lights i go to brake it just drops to 200rpm, 5 out of 1 it will stall at the lights?
    does it all the time dont know why??
  2. Cursed CX8
    Cursed CX8 Banned
    Walking distance to FG meets
    VY Adventra
    IAC?
    Maybe reset the ECU and then reset the IAC.
  3. h0Ld3n`VN
    NO CAR ATM.. -.-
    i reseted the ecu a few times.. still the same, how do you reset the IAC?
  4. Bz Kn33z
    Bz Kn33z Active Member
    Mildura
    Black VN V6 Turbo
    get some throttle body cleaner and clean out the T/B and clean out the IAC while your there chances are its clogged, is the engine light coming on at all, before you stall dont reset the computer untill you get a code, wait for it to give you a code the see what it is if the engine light is coming on, but i would start with cleaning the T/B out
  5. h0Ld3n`VN
    NO CAR ATM.. -.-
    yea i checked error codes many times, just changed my sparkplugs they were destoryed.. throttle bodys clean as, n i gave it a clean anyway while i was at it.. wheres the iac located?
    engine light error code does come on n i know whats it from, my speed sensors dead
  6. Bz Kn33z
    Mildura
    Black VN V6 Turbo
    IAC (Idle Air Control), located in the throttle body, at the back of it,
  7. h0Ld3n`VN
    NO CAR ATM.. -.-
    how do i reset it? it might be my ecu tooo grrr
  8. Bz Kn33z
    Mildura
    Black VN V6 Turbo
    Get a mates ecu and put it in the car see how it goes, you cant reset the IAC unless u take the battery terminals off, and reset the computer.
  9. vn calais manual
    vn calais manual New Member
    vn calais, vs clubsport #137
    it will be your IAC valve.
  10. h0Ld3n`VN
    NO CAR ATM.. -.-
    allrite thanks guys been reading on a few other threads.. there could be crap stuck in there, if not i gotta get a new one.. if reseting it doesnt fix
  11. Bz Kn33z
    Mildura
    Black VN V6 Turbo
    get some T/B cleaner and spray it into the holes in the T/B it will get into the IAC and clean it, or take the T/B off and unscrew the IAC and see if there is any problems with it, and clean it properly out of the car.
  12. Anthraxnz
    Anthraxnz New Member
    Wellington, New Zealand
    VN Executive
    Throttle body is easy to get off, just 2 nuts but watch the gaskets ;)
