Seaair
- Nov 18, 2015
- 7
- 0
- 0
- Location
- Launceston
- Landcruiser VR v8
Ignition issue for the Guru,s.... I have a Landcruiser 80 series with a marks conversion running a VR V8 Calais engine etc. it randomly stopped working after my inlet manifold gasket was replaced. It runs well for a few days then stops while driving then takes up to a week to start again. It stopped again on Monday had a long walk home after draining both batteries. Did a lot of reading and worked through most of the things to test the ignition module but got to the last test which was to disconnect the 6 pin from the module bridge the grey/red to the black and the White /black to the red then use my low power led test light on the blue/white and connected to the positive battery and then crank over.... No blinking of the test light.. Sooo thinking it is not he Hall effect sensor... Interesting though reconnected the 6 pin to the ignition module and it started... Hmmm... Then made it a little down the road and stopped again, repeated the process and she fired again made it ho,e and parked her up.... Given all the info does this sound like I need to pull her to bits and replace the Hall effect sensor or any other ideas before I rip off the intake manifold etc to get to it?????
Open to suggestions
Thanks heaps
Open to suggestions
Thanks heaps
