Pedroman5128
- Dec 29, 2012
- 17
- 0
- 1
- Age
- 63
- Location
- Adealide
- ZB Calias V 2019
My lane change alert does not beep if I unintentionally cross the white lane line. From memory and I'm elderly it has always beep beep beep if the vehicle goes near the line and vehicle corrects it self with auto steering applied to bring it back to the lane. I have a my19 calias v. AHolden where I took it said that's normal as they do not do an audible beep in this situation I have checked the settings and it gives an option to disable if required mine is set to active so it should beep. Can you please advise as Holden have a different opinion. Also the volt guage sits well under 14 volts even at night at times when lights are on. They also advise that is how it works at other times it will sit just above 14. Is this correct. I can recall where the lane change assist beeped and the volts always sat just above 14. Thankyou for any responses
Thanks for all the responses Also note on page 306 in the manual it states there should be an audible tone in the above situation. Also please advise re the volt guage dropping to about 10 / 11 whilst driving, I think it use to always sit just above 14. TY
