Leads falling off
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by mking, Feb 11, 2009.
  1. mking
    mking New Member
    Newcastle
    Bagged vs caprice sII
    Hey recently been having problems with my spark plug leads falling off when i give the car some and it revs fairly high but only on 2 od the cylinders, replaced the leads and plugs about 4 months ago and ever sinse that its been happening, probably happened about 4 times , anyone have any idea?
  2. EREXON
    EREXON New Member
    VS Calais Series II
    What leads did you buy.
    You can take the leads off and if you look inside it, its basically a round metal clip that sits onto the spark plug.
    Get some needle nose pliers and just close the pins up abit. That way its tighter onto the plug.
    Make sure you dont break it though its a small circular piece.
  3. EREXON
    EREXON New Member
    VS Calais Series II
    Maybe try it on the old ones just for pratice first
  4. dufus
    dufus Donating Member
    rickshaw
    Yeah sounds like you have busted clips, just create a smaller tolerances for the clips by bending them in a little, though if it was be id buy brand newies, but that's just me.
  5. mking
    mking New Member
    Newcastle
    yeh i think ile just go buy some top guns then, they were bosch supersport i think
  6. kopper69
    kopper69 New Member
    VRII Acclaim
    Just get some pliers and crush the connector a little (while it is off the spark plug). When you push the connector back on it will sit nice and tight on the spark plug. Just a little though. Little bit at a time, take a couple of goes if you need.
  7. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    It's also possible you are not pushing the connector far enough onto the sparkplug to lock onto the nipple - I find smearing the inside of the connector with silicone grease allows the connector to slip on with ease and you can feel the connector lock on.
