Leak in Passengerside Footwell
B
Bloka
Guest
Hi Guys
I have a '97 VS S Pak Ute
There is a damp wetpatch after it rains only in the passenger side footwell.
The windscreen doesnt leak and none of the heater hoses are broken or cracking.
It looks like it starts from just undernearth where the computer is.
Does/ has anyone had this problem? Or know how i can fix it?
Thanks
The1985divo
35
VF Calais V
i had this problem, pull up the carpet and i found that there was a hole that was ment to have something in it, so i jus siliconed it up and all good :)
hope that helps
IanG
photobucket.com
Blown VS Wagon
I've have the same problem with my VS wagon but it's only a problem if I take it through a high pressure auto car wash. {CL's} I thought it was the heater box but all seemed okay. It came from somewhere under the dash because I had some junk on the floor that was wet on top. I suspect a vent or a seal.
I'm going to jam a short relative under the dash and get it washed again soon.:)
88GreenVN
Next Exit Left
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
Check the arial were it come thru next to the computer.
B
Bloka
Guest
Thanks for all the responses.
It rained on the wend and it looks like it is the seal around the door. I am pretty sure. So I am going to move the seal around a bit and then see how I go from there. Thansk again Champions
B
Bloka
Guest
I have worked it out.
I have put two cuts in the black rubber one in the corner near the hinge at the bottom and the other in the back corner. Seems to have fixed it.
But this week will be the big test as it is meant to piss down rain again all week.
