garfa
- Aug 29, 2004
- 1,937
- 22
- 38
- Age
- 37
- Location
- SE Victoria
- VY SS
hey guys,
i think a mechanic has overfilled my transmision with fluid. the fluid level is about 1.5 inches about the full mark. also there is fluid on the bottom of the pan.
is the fluid on the bottom of the pan because its been over filled or would the gasket be leaking? if its a leaky gasket (cork) can i tighten it but a little and stop the leak or is it like a metal head gasket where you just gotta replace it? how can i drain the fluid in the trans? is there an easier way than just removig the pan and adding the fluid again? (the fluid is 1 month old)
cheers, garth.
cheers, garth.
