Leak
The Lion
52
townsville
HZ TONNER ,C1500 Chevy , VX DAILY DRIVER
Just wondering if a radiator block would solve a coolant leak between the motor an box if it just a few drops overnight.
Trevor loves holden.
vs commodore
Band -aid fixes lead to more issues, I say you posted in the wrong section, if its a vz then happy days. To fix it its a pain in the arse as you probably already no, depending where the leak is if its hose then no, if its a seal maybe maybe not. Better off getting it fixed that means hours in labour cost if you cant replace the thermostat seal. There 2 options remove the transmission or striping down the top half of inlet manifold and with small hands and lot of patience you get it, it maybe just loose, if you go ahead replace the thermostat as well wile your at it..
Vin999
SA
VSedanS
sure it can work but just like life, its only temporary, not permanent
