camer0n
- Jan 14, 2013
- 16
- 0
- 0
- Location
- Auckland
- VL Vacationer
I have looked through other posts and found similar issues with this fitting but none have quite had the severity of corrosion of the fitting in my VL
This is the T fitting off the heater hose (two hoses run parallel with each other to the fitting).
When I removed the hose trying to find the cause of the coolant leak it was pretty clear that the corroded lip is most likely the cause. There is no splits or pin holes in the attaching hoses.
I don't want to remove the fitting for fear of shearing it off (given its current state). I was thinking of inserting a smaller hose and somehow fixing it to the fitting or building up the corroded edge.
Does anyone have suggestions on the best way to do this or perhaps a better solution?
I have attached some pics of the fitting. The small hose that comes of the fitting and runs up to the plenum is still attached and the corroded lip is on the underside of the T fitting.
Any help would be greatly appreciated
