leaking from kickdown cable
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by stocky, Sep 2, 2008.
  1. stocky
    stocky New Member
    having a problem with my auto. its leaking a lot of oil out of the spot where the kickdown cable connects to the auto. i changed it a couple of weeks ago. is there an o-ring that is supposed to go on the cable before i put it in? i never saw one but have read that about the t350s. any help would be good
  2. stocky
    stocky New Member
    bump. do kickdown cables use o-rings?
  3. jas98
    jas98 Active Member
    maryborough QLD
    vs commodore V6 S2 and a BA XR6T
    should be a bolt (about 10 mm i think) near the kickdown cable when it enters the g-box. then u have to unhook the kickdown cable and take out the O ring ...so yes there is a o ring:thumbsup:
  4. stocky
    stocky New Member
    hmmm, i got the bolt on, and the cable on the hook, but cant remember an o-ring. was it in the box, or the plastic holder for the cable? i didnt drop the box, so it was a tight fit to get in there so thats why i may have missed it.
  5. jas98
    jas98 Active Member
    maryborough QLD
    hmm well theres either a oring or a small gasket type thing there...i know theres something there otherwise the oil will leak
    could be a flat type o ring...ill check and let you know
  6. Cheap6
    Cheap6 New Member
    VP Exec
    It's been a while since I've had one apart but I think that the 'O' ring is in a groove in the plastic end of the cable.
