VK SL 3800
vn vp vr vs tanks fit but you have to modify the filler as its too long, ill be putting in a VS tank soon as my VK EFI one has started to leak right on the bottom.
TY318 Yes there is aftermarket ones I have seen a few of the older commodores running around with drop tanks. I dont know of any for sale though. I am running an EFI pump to supply my carbs but my fuel supply is a bit on the extreme side. I must admit the thought of having to change all my wiring and plumbing to suit the new tank isnt going to be fun but should only have to do it once. I hope. I am a bit hesitant to weld a fuel tank, I know it can be done but it kinda seems a bit scary lol. But it would be so good just to get my tank fixed and not have to modify jack.
so was mine, did this:
no more leaks
Im having problems with it rusting out from the inside, there is thousands of tiny rust pitting holes inside and i have already soldered it up 3 times but its just springs a new leak in a slightly different spot, currently i have put 515 over the hole with a piece of plastic lid over it to make it dry, does the trick for the time being, it is dodgy as hell but what else can i do when its my daily drive.
wish i could weld that good!
