Hey Guys, Will replacing the vapour lines around the fuel tank on a VN fix a leaking fuel tank? Thanks
Not if its got a crack in it If you are seeing a wet patch on the tank, it should do. My SS had the same thing, I replaced every single hose around the tank and it solved the problem.
