leaking v8 thermostat housing vs/2
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by vs hay hauler, Sep 27, 2008.
  1. vs hay hauler
    vs hay hauler New Member
    vs ute
    about a month ago i replaced the thermostat,the local spare parts shop supplyed me with a standard flat gasket.when i removed the thermostat housing i noticed it had an o ring so i went and used the flat gasket,anyway after a week it started to leak so i removed it again and replaced it with a genuine o ring three weeks later it starting to leak when it sits around for a few days.do these housings warp and should i try replacing it this time?:bang:
  2. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    You need to coat the "O" ring with silicone grease or similar to make sure it seals good unless you are using a new thermostat housing. Sit the housing on a sheet of glass to see if its warped. If the housing is corroded I'd replace it anyway.
  3. vs hay hauler
    vs ute
    Thanks mate will give a go tomorrow.
  4. VrWagz1
    VrWagz1 The Wagon on Wheels..
    wollongong
    VE SSV MY09 Auto Wagon
    I coated mine up with that black gasket gooey shize. Hasnt leaked yet, and i used a crappy thin 3rd party O ring.
