LED number plate lights giving warning...
Discussion in 'VY Holden Commodore (2002 - 2004)' started by vongy10, Mar 11, 2018.
  1. vongy10
    vongy10 Active Member
    Gunnedah
    CV8 Monaro V2
    Hi all,
    Decided to upgrade some lights on the car, threw LED bulbs in the number plate area and that sets off the warning in the dash that's annoying af. I might want to upgrade the bulbs for the tail lights too but no way if I get that warning everytime I start the car. Is there a simple fix or does it require soldering a resistor?
  2. HSVBMW
    HSVBMW Member
    South Australia
    vh vn vt
    You need 'canbus' leds,standard globes are 5 watts,led 3 watts. If car senses anything below 5w it thinks its blown. Canbus just means it has a circuit that boost the current draw to 5 watts thus stopping warning. You may find they flicker at start up,its just the computer checking the bulb circuit. Its not visible with standard globes as they are slower to respond than leds.....so not an issue...car doing its test.
    vongy10 likes this.
  3. vongy10
    Gunnedah
    CV8 Monaro V2
    Thanks for that. I find it kinda odd that the warning came up for the number plate bulbs when I swapped them but it didn't tell me that one of my front parker's was out...
  4. Voodoo_SV6
    Voodoo_SV6 Active Member
    MY12.5 E3 R8 Manual+MY16 VFII SV6+MY11 VE S2 SV6
    I had the same. Front parkers are all good, but the number plate leds set off the warning. I just changed them back to standard
  5. HSVBMW
    HSVBMW Member
    South Australia
    vh vn vt
    If you have changed your parkers to led and they ARE canbus leds they will never show bulb failure.
    The canbus circuit continues doing its job even when the bulbs blown.
  6. vongy10
    Gunnedah
    CV8 Monaro V2
    Got some canbus bulbs, threw them in, they light up but I still get the warning which sucks.
  7. _R_J_K_
    _R_J_K_ Well-Known Member
    Zenki S14
    I doubt it's a wattage issue that causes it (for Commodores atleast), it's the lack resistance on the circuit you get from LED globes as they left the factory with incandescent globes that give more resistance. It's happened with brake lights and cruise control, so if you throw them in the tail lights your cruise control likely won't work (this seems to be by design as it's on almost(?) every model Commodore with cruise control). Throw LEDs in the indicators and they will probably blink as if there's a blown bulb. I'm unsure of what kind of resistance needs to be on the circuit as I've never done it.
  8. vongy10
    Gunnedah
    CV8 Monaro V2
    Seems like disconnecting the battery for a bit did the trick.
