Led size
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by madsav, May 4, 2011.
  1. madsav
    madsav New Member
    your ass
    your ass
    Hi guys just need to know what size LEDs are in the hazard switch and the LCD display ? Are they t4 or t5 , I tried t3 but too small
  2. wrx884
    wrx884 WA's ASR Rep
    VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
    T5, tho if ur talking about the clusters LCD screen u'll notice the globe holder is slightly taller 4 a reason, so u'll need 2 use the same holder or find 1 with the same height. The hazzard switch how eva is exactly the same except shorter in height tho do remember if ur putting an LED in there u need an LED 2 project sideways so it lights up properly, otherwsie u may find it will b slightly duller than ud expect as the light is projecting straight into the hole and doesnt get very far like a normal globe would as it can actually project a 360* angle of light, LEDs cant.
  3. madsav
    madsav New Member
    your ass
    your ass
    What about getting the mode button/light switch and hazard lights to work since the standed ones wont even work now :( will they work again if i slap an LED in them too? or would u say maybe a fuse problem?
  4. wrx884
    wrx884 WA's ASR Rep
    got a test light? test and make sure u got power there but if u havent best check the fuse if u havent already. u can put LEDs in them, the headlight switches globes r soldered in place so u'll need 2 solder in LEDs if thats wat u wanna use.
