Left Rear Scrubbing
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Jackv8, May 2, 2012.
  1. Jackv8
    Jackv8 Member
    Central Coast
    VF2 SS LS3 6.2L
    Hi all,
    I recently picked up some schmick 20 inch versus wheels after fitting and driving it i noticed the left rear is scrubbing and there is no gap, i've done my research and by the looks of it if my diff needs to be centered it usually causes the rear drivers side the scrub! Would a adjustable panhard rod fix it or will i need extras? I have super lows all round
    rear tyre size 245/45 & front 225/45
  2. UW1SH
    UW1SH New Member
    yes adjustable panhard bar should fix it.. I have 245s on my car and a adjustable panhard bar and it dont scrape at all...
  3. Jackv8
    Jackv8 Member
    Central Coast
    VF2 SS LS3 6.2L
    Ok thanks i was just worried i would need extra modifications to fix the problem!
    btw is $180 around the right price for one?
    cheers jack
  4. Chrispy
    Chrispy Member
    VZ Calais, 2015 Daytona 675R
    I paid $108 for a whiteline one from eBay. Shop around, $180 sounds right for a Nolathane one tho.
  5. Jackv8
    Jackv8 Member
    Central Coast
    VF2 SS LS3 6.2L
    Yeah that was for the nolathane but I'll keep shopping around like you said :)
    Also is it bad to drive around like that ?
  6. UW1SH
    UW1SH New Member
    Yeah you will tear your tyre up and haft to fork out a few more hundred for another tyre
  7. Jackv8
    Jackv8 Member
    Central Coast
    VF2 SS LS3 6.2L
    Faaaark in that case I need it ASAP
  8. yxyx64
    yxyx64 New Member
    nsw
    Kia turbo + Holden badge, Chev badge in Texas
    What sort of front suspension work do you have ?
  9. Jackv8
    Jackv8 Member
    Central Coast
    VF2 SS LS3 6.2L
    Only replaced the sway bar links few weeks back myself but that's it a lot of it needs replacing but I did fit new fewer shocks b4 I put the kings in
  10. yxyx64
    yxyx64 New Member
    nsw
    a 225/45-20 is a pretty tall tyre (about an inch and a half taller at the tread than say a 245/45-18). I'm surprised it does not hit the spring perch on the strut but you are out there doing it so it must not.......must be close though.
  11. Jackv8
    Jackv8 Member
    Central Coast
    VF2 SS LS3 6.2L
    when I got the wheels the other day I didn't check the tyre size and put one of the 245/45-20 on the front right and drive off tyre started smoking sounded like a f****n train man " i was like fark me tyre" whoops" but yeh the 225/45 on front are great enough clearance at full lock tho it rubs slightly but driving there fine, less u- turns now haha
    I went from 16 inch VX spac wheels to these huge 20's and it's a massive change for me :)
