Legal lowest I can go on front S3 vs ute
JackHullen
Australia
S3 vs ute
Hey guys I've just been given a set of lenso d1's 18 inch from my brother I'm wanting to put them on my Ute but don't know how low I can go without them scrubbing my guards they are 235/40.
I'm ok with guards being pumped/rolled and will Get spacers if needed. Any help would be great cheers.
steve.
SA
VS V6 Auto, 5 Speed ED Falcon.
the rolling diameter will be almost exactly the same as the stock wheel size, so you won't hit the guards as long as your ute isnt on sssl's
as for the width, I run 235/45/r17's (almost identical rolling diameter as your wheels) on my VS sedan and they fit perfect, no scrubbing although at full lock they are close to it, thats on kings sl springs
What offset are the wheels? think stock is +37 or +43, my wheels (vx ss wheels) are +48 and fit perfect
steve.
SA
Should be stamped/printed on the wheel somewhere, or you can measure it yourself
JackHullen
Australia
S3 vs ute
Sorry I took long to reply, I just measured the offset, it's 45
steve.
SA
99% sure they'll fit fine then, chuck them on for a test fit
_R_J_K_
Zenki S14
All of this info will depend on the width of the wheel. Without the width, the offset is useless and you can't tell the rolling diameter.
Lowest legal will probably depend on your state, some go by 100mm rule, others by eyebrow height.
steve.
SA
uh, yes, you can tell the rolling diameter, in his case its 645mm, 2mm less than stock
and his wheels are obviously 8 inches wide as the have 235mm tyres on them
_R_J_K_
Zenki S14
I don't know how it would be obvious, I've got 235s on a 9.5" wide rim. I was wrong about the rolling diameter, but the offset will still need the width.
H
harrop.senator
Guest
Was going to say lol ive had 205s on 9s and 235s on 10s. 235s can go on anything 6" to 10" pending how game the fitter is. +45 is high as you wont have much difficulty clearing guards unless ridiculously hekkas illegally low.
