legalities of an engine swap
ari666
250,000 hits
can anyone tell me of the legalitys regarding dropping a 308 into a 6 vb-k commy?
i am in vic.
my boot has terminal rust and i think before i go repairing it i may buy a 6 cylinder body and swap all my good parts over.
is this gonna cause me headaches with vic roads?
thanks.
greenfoam
VP Executive R-spec
No, so long as you have the correct manifold and emmisions hoses on it it's just a matter of updating the engine number info etc down at vicroads. Same goes for any factory engine swap or anything that is of similar power/weight to one of the optional engines and bolts in (RB30 etc)
crazy.vr
VR Commodore
As long as you have a intake manifold to suit a blue or black 308 motor with an egr valve and also a pollution quadrajet carb there won't be a problem.
JoshSvc
Central Coast, NSW
VN Sedan - The Beige Bandit!
Yes i believe that you have to run the pollution gear that the car came out with for that motor.. or if the motor is newer than the car u have to run the pollution gear for that motor from what it was out of... Correct me if i am wrong.
Josh
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Correct. You must comply to the regulations for the year of the latest part, be it the engine or the body.
EG: If you put a VK engine into a VC body it must comply to the VK emissions regulations. If you put a VC engine into a VK body, it still must comply to the VK regulations.
ari666
250,000 hits
does the car need to be inspected by vic roads? i.e new issued RWC and over the pits? or is it a simple call up and change thing?
here is another one. if i was to put efi on my current 308, would i need to comply with the ADR's for the fuel injection? bearing in mind that the block and engine number would be the same. just changed heads, cam, inlet and ex?
