Bit hazy vaguely remember taking trimatic shifter out drilling hole larger to accept 4l60e selector rod/bolt combination & put it all back in.
Front of trans pan/auto on drivers side probably touches tunnel so check auto is straight or you'll need to clearance it.
Can't remember what accelerator cable I used if v8 or v6 or might even be similar lengths *shrugs*
Did you change vh radiator tiebar over to vr/s stato donor item so you can fit later model radiators?
Hey nice work so far, I bet you have worked out there’s a lot of lil stuff that needs buttoning up that people don’t mention, those things take more time and effort than putting in the simple big stuff like motor/trans.Ahhh bugger I just left the trimatic rod/arm in it.. I've messaged the bloke who bought my donor hoping he's still got the shell with the VS one..
So far the trans looks like there's clearance, but I need to get back under the car to bolt the mount to the xmember and double check - looked good during installation so fingers crossed..
Throttle cable was a piece of cake, I used the VS one. It had a plastic sleeve over the firewall lug to increase its OD, but once I just pulled that off, it just slid straight into the original firewall port and the cable clipped into the pedal perfectly. Easier than I expected to be honest..
I didn't change the radiator tie bar as it looked like a PITA so I bought an alloy radiator from eBay, suited to a V8 VH. That's the next thing to install!
Fuel lines are all connected, as are the heater hoses. Installed the aircon bracket to correctly space out the P/steer pump, but left off the A/C compressor for now till I can be bothered working out the A/C and evaporator later on.
I've hooked up the loom as much as I can today. Almost everything from the ECU to the engine:
Next steps would be figuring out where the other main loom line goes/what I need from it (the two large black/grey plugs in the engine bay that hook up to the drivers side loom in the VS) - do some of these connect to the VH's loom? Time to review some wiring diagrams me thinks!!
- Injectors
- Oil pressure switch
- TPS & IAC
- Coolant temp sender
- Ignition module (just figuring out where the hell to mount it)
There's also a small black box in the loom with a vacuum line input - I reckon its a MAP sensor, but I can't remember where the vac line should come from the engine.. I have a horrible feeling it comes from the back of the intake manifold, lol
If you can, get the tail shaft phased once you match the two halves. They can be a prick for wobbling if they are not set properly and this can cause a blow out in the centre bearing. Also if one is still available used a Gen bearing. Aftermarket ones are problematic even the brand name ones. The boot is too soft and doesn't support the bearing enough and can also cause it to blow out.
Trace green wire off temp sender through harness then tap into engine loom or harness plug at firewall.Should be 2 greens from memory for ac compressor other for temp sensor.
Did you keep 6cyl engine harness?
green - temp sendor
blue - oil pressure sendor
pink -accessories
red - 12v
purple -starter solenoid
brown - charge light/alt
Should be able to join vh sender wire to stato fuel pump/sender wiring & use purple wire(f/pump wire) from that out of stato as power wire like factory did or better yet trigger wire for f/pump relay kit like you can get get from bluewire.
