Level 1 dash cluster to level 3
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by SSbeast, Oct 2, 2006.
  1. SSbeast
    SSbeast New Member
    Is it possiable to put a level 3 digital dash cluster in a VR that had Level 1 normal cluster? Do i need a new BCM? and/or sensors?
  2. markovr
    markovr Well-Known Member
    northside brisbane
    07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
    Yes very possible and covered many times on this forum try searching under level 3 , trip computer try this thread to start http://forums.justcommodores.com.au/showthread.php?t=994
    All you need is the cluster the right engine and model for your car,dash loom modified to suit your car and buttons module....no bcm change or anything else.
  3. Fekason
    Fekason Fekason
    Penrith NSW
    Yes it is, but!
    You could swap to a Level 2 VR/VS cluster by a straight swap, to get a tacho.
    The swap to a Level 3 is a bit more.
    You will need the following:
    1) A level 3 cluster from a VR or VS. A VN or VP cluster will cause smoke.
    2) The trip computer buttons.
    3) A patch wiring harness to connect the trip computer buttons and the cluster fourth connector.
    The most difficult task is sourcing a wiring harness to make the patch harness from. It is possible to buy a new harness for this, but cost is not cheap.
    Many have done this mod. Most have got through without undue problems, though some have struggled.
    It is important to get a V6 or V8 cluster as appropriate as it is not possible to set this through a calibration like later models. It is possible to modify the tacho to fix this, but easier to get it right from the start.
  4. Torquen
    Torquen Boost FTW
    Perth, WA
    450+ HP FORD XR6T
    iv sourced all that parts now. cost me $300 for the 3 parts. now i just need to find some one willing to put it in for me.
  5. semi
    semi GOD
    WA
    VR exec wagon
    i wouldnt mind giving you a hand, its something im interested in doing maybe down the track, and ive read up a bit about it
  6. Torquen
    Torquen Boost FTW
    Perth, WA
    450+ HP FORD XR6T
    were bouts r you in WA? pm me.
  7. noizwerx
    noizwerx New Member
    VSII Exec
    Just about to start the same thing as soon as the car comes back from the panel beaters. Keep in touch and we'll compare notes
  8. Torquen
    Torquen Boost FTW
    Perth, WA
    450+ HP FORD XR6T
    ok. any one lookin for the parts to do this conversion PM me. i have all the parts, but am getting a new car at the end of the year so have decided not to go ahead and put them in. i payed $150 for that dash, $90 for the wiring Harness and $50 for the trip computer. if some one from JC wants it you can have it for $250. again PM me if your interested.
    cheers, jesse.
  9. Torquen
    Torquen Boost FTW
    Perth, WA
    450+ HP FORD XR6T
    ohh and the dash has no LCD leakage and has around 240k on the clock.
  10. GTW05
    GTW05 New Member
    Brisbane South
    1998 VS 50th Anniversary Ute
    Any contact details for someone in Brisbane doing these conversions?
  11. 88GreenVN
    88GreenVN Next Exit Left
    Surprise, Arizona
    Dodge Ram Van 1500 5.2 V8
    Markovr on the JC forum here - he'll help you out.
  12. Demonica
    Demonica Mrs Wraith
    SE Qld
    VS clubsport
    Its not that hard to do the conversion yourself. Only takes half hour or so and all you need is a lil patience. I just bought everything I needed from Greeny and went for it lol.
