Shaundy
BMW Technician Apprentice
- Jan 12, 2009
- 90
- 0
- 0
- Age
- 34
- VS Executive S2 BT1
Hi all,
I have an issue with the level 3 cluster I installed yesterday. All functions appear to work correctly except for:
-The tacho. It will display the revs however when accelerating in econ mode it with suddenly drop a couple of hundered rpm just before it changes gear, at which point it picks up again to where is should be. When accelerating hard in power mode, the needle will drop back to 0 a couple seconds before the gear change at which point it again springs up to where it should be. Whilst revving the car in park I found the the needle will not make it past 2500rpm before it drops. Has anyone had this issue? I suspect there is a dodgy connection somewhere however I am not sure where to look.
-The distance to empty display. It displayed a number when I had first plugged in the new harness just to test it, however it now simply shows 0 all the time.
-The LCD lights. When I turn my headlights on, the LCD lights go out.
-Speed alert light and buzzer also do not activate when the set speed is exceeded.
Could someone tell me what is the combo of trip buttons that need to be pressed to activate the diagnostic display on the dash?
Any help would be greatly appreciated.
