Level 3 highly customisable clusters
VPGTS076
44
melb
vp gts
Hi guys,
I am developed highly customisable clusters for example:
• 7K Tacho & 250KM/hr Speedo to suit LS
• 10K Tacho & 250KM/hr Speedo to suit V8
• 8K Tacho & 250KM/hr Speedo to suit V6
• Possibilities are endless. 
Currently Temp gauges is being immensely tested. The aim is to allow for simple and painless conversions while still displaying correct and accurate temperature readings.
This is done without the use of without special conversion boxes or needing to utilise V6 or V8 senders (which requires modifications) on LS series conversions or replacing you V6 Dash in V8 Conversions.
• Temp
o To suit LS series ( In Testing)
o To suit V6
o To suit V8
Currently Speedo gauge is being immensely tested. The aim is to allow for simple and painless conversions while displaying correct speed and accurate speed readings but allow for customisable top speeds.
These are calibrate using factory 3.08 gears and factory speedo sensor and factory gears in VN & VP’s. These do not need any special speedo conversion box.
If demand is high enough I will eventually provide calibration with other gear sets…
Currently I am thinking of the following top speeds
• Speedo
o 220KM (Factory)
o 250KM ( Factory HSV)
o 250KM ( no HSV LOGO)
o 270KM ( In Testing)
o 300KM ( Coming Soon)
o 320KM ( Coming Soon)
Currently Tacho gauge is being immense tested. The aim is to allow for simple and painless conversion while displaying accurate Tacho readings.
This is done without special conversion boxes or needing to modify wires on LS series or replacing your V6 Dash in V8 Conversions.
Currently I am thinking of the following Tacho RPMs
• Tacho
o 7K ( factory)
o 8K
o 9K
o 10K
The other features that I will be exploring are a built in Shift light both single and multi-point adjustable and fixed.
Pricing TBA.
If you have any questions, requirements please email at [email protected]
Thanks
Daniel
kilebantick
Maldon
Holden Commodore VN Calais 1989
What's the chance you can also fix clusters that are currently malfunctioning? My speedo drops in/out and can be brought back by a good wack, my tacho drops in/out and can't be brought back with a wack.
Jxfwsf
Aus
commodore
The speedo shouldn't be much of a problem
Only in vn/vp was it driven directly from the vss, (vr v8 and early vs v8 manual were as well) vr auto onwards was driven from the pcm, with the LS pcm's you'd just feed the speedo from pin 50 on the red or green plug, easy to calibrate in the tune if ratio's are changed.
VPGTS076
44
melb
vp gts
Hi MAte,
No extra wires / boxes required... Plug and play....
Thanks
NickVR
40
Adelaide, SA
VR Executive A4 V8
Can you do faces that look factory but light up white instead of green? HSV 250km cluster with HSV symbol too.
88GreenVN
Next Exit Left
60
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
Email sent to find out more info.... :) this could be good stuff for cluster fetish people like me LOL
VPGTS076
44
melb
vp gts
Hi Shane,
email responded too...
Yes been a two year addiction :)
VPGTS076
44
melb
vp gts
I am getting these made in the US and will ask my supplier....
Are you also chasing LED mod?
NickVR
40
Adelaide, SA
VR Executive A4 V8
I have always thought about it. The cluster is hard to change to white light while looking factory still. Especially the HSV ones as they have the logo on it. The AC controls are done and on ebay but not the dials.
Redline16
MY16 VFII SSV Redline Manual
Would love a 250kmh one for my Calais with out the HSV logo :)
As long as speedo is going to still be accurate
Let me know price!
