Level 3 v6 v8 cluster diferences
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Mr Ute, Jun 23, 2008.
  1. Mr Ute
    Mr Ute New Member
    VR HSV
    What are the diferences from the 6 a 8 level 3 clusters.There was a post on this earlyer on what to change on the 6 cluster to work with a 8 but cant find it.Im guesing the tacho was diferent.
    Any one no??
  2. stocky
    stocky New Member
    tacho has 1 resistor different. not sure which one
  3. Mr Ute
    Mr Ute New Member
    VR HSV
    do you no if that is the only difernce.If thats all ill just swap my tacho over in the cluster
  4. Fekason
    Fekason Fekason
    Penrith NSW
    Tacho + Fuel Guage Are Different!
    I understand that the the tacho and fuel guage are different. However, it is possible to live with the fuel guage difference.
    From memory, the V8 tacho has one extra resistor and one repositioned resistor.
    If you have them, easiest solution is to swap the tacho to the one you require.
