Since no1 here willing to HELP/SHARE altough few said that they already done it without giving out the SECRETS,can somebody KINDLY tell me where i can get it done professionally,in Melbourne.
ring any auto elect, they will do it if they have the diagrams, have u even searched for this topic? its been covered a far few times.. i found out how to do mine on here, wif the help of mark0va , good luck if u try attempting your self
Hey dude, I'll provide you with a few links. option one: http://forums.justcommodores.com.au/showthread.php?t=33334&highlight=level+cluster but Option two here is the one you will use: http://forums.justcommodores.com.au/showthread.php?t=994 I'm thinking of doing this also, let me know how you go
Hey, Vt_Acclm, have you fitted your cluster in yet? Its not that hard, give me a buzz,and can explain it for you, as long as you know how to patch wires into other wires, your 80% there...Im sure an auto elec will want your left nut for that type of work, it will take you a couple of hours to do.....
theres a very good guide on another commodore site(s t r e e t c o m m o d o r e s), hopefully you can guess which one, in their FAQ section.
Auto Electrician Charges Hi, I know of an auto electrician (but in NSW) who did a conversion at commercial rates. Cost was $216, including GST.
Penrith Hi, Can't find them in the phone book at the moment. They were in Peachtree, Penrith. I'll drive by tomorrow and confirm that they are still there. They did the job about 18 months ago. Took about three hours plus a few assorted bits. Cost did not include the cluster, trip computer buttons or wiring loom. Cheers.
u have to trace the wires from the trip loom adn wire into yours. adn also there is 1 wire that need to be wires to the comp so as the fuel funcs will work
Penrith Auto Electrician Hi, Sorry for the delay. Got too busy. The following has done a conversion as discussed above: PEACHTREE AUTO ELECTRICAL SERVICE PTY LTD 1-2/ 39 Peachtree Rd Penrith NSW 2750 (02) 4722 9750 Good luck.
i am doing the conversion currently, and have found that if i can pull the tape off the looms and wire my old AC wireing into my new berlina harness everything shud work, just a matter of cutting the plug off and wire in the same spot on your new harness
hey i just compleated the conversion last week took me brother 15 minutes to wire the trip computer in to my old loom, 1st) he traced the wires for the speed alert plug n cut them off but remember where they went. 2nd)he removed the white plug and controll plug from the berlina/calais loom still remember where the wires go. 3rd)he wired the trip wiring into the old loom, he matched wires by colour code for instace brown with white tracer is illuminum, ect The only wire that is not run through your loom is a yellow with black tracer, that wire must be run behind the dash to the computer where it is joined to the corresponding wire (same colour), the wire from the computer goes into a plug and stops so just a matter of finding it, cutting it and joining the two, good luck
