Light issues.
confrontation
39
VF 2014 Holden Commodor Evoke
Hey Guys.
Im getting light warnings on the dash.
  1. Check Right Dipped Beam Lamp
  2. Check Right Position Lamp
  3. Check Break Lights
  4. Check Right Front Indicator
I have looked at 3 of the 4 bulbs and have seen they are not blown.
I have replaced the 2 break lights and the Right Dipped Beam Lamp.
I have also checked all fuses in the boot and bonnet and they are fine, am I missing a fuse box anywhere?
Im now confused as to why they will not work, nothing in my opion is wrong unless there is another fuse box I dont know about.
Any help would be great.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Have you checked the cabin fuse panel, on the R/H end of the dashboard?
There are 7 different BCM fuses in the panel that might be causing your problems.
confrontation
39
Can not seem to locate that
vywgn
1967 Holden HR Premier Wagon / 2015 VFII SV6 Sedan
Open the door and it's behind the side cover of the dash, where the headlight switch is you'll see a little slot to place a screwdriver in to pop it off
lmoengnr
Donating Member
Sunbury Vic.
Do you have the Drivers Handbook for the car?
It will detail the 3 fuse/relay panels locations, how to access and fuse/relays numbers.
preoj
SV6 VF
Hey Guys.
Hey mate,I know this was posted a while ago but do you happen to remember which fuse is for the RH Headlight,blinker etc I now have the same issue
Forg
Regal Peackock VF SS-V Redline Wagoon
@preoj does this diagram help?
(it's actually on the back of the fuse-box cover)
(Googled for it - assume it's correct)
preoj
SV6 VF
I have checked all these fuses and they are fine,I found another post saying check the panel on the right side of the dash,these are big chunky relays,how can you tell if they are blown or not.Cheers
