Lights dimming badly!!
Cameron P
Quakers Hill, NSW
REDHOT VX SS
How can I fix my interior and exterior lights dimming when the bass hits? I don't even want to hook up a voltage meter lol
kcpwns
Kicker - Livin' Loud :)
Shepparton
VY V6 Equipe
Kinda battery you run? Optima yellow tops are great, talk to vkcommo about getting one. Also doing the big 3 upgrade helps with voltage drop. Do a search on here about it.
Kinda set up you got running?
Jesterarts
Your freedom ends where mine begins
2010 Nissan X-Trail ST-L
It's called a capacitor...
Not sure what size you would need, but bigger is better within reason.
Put it somewhere along the power line and dimming interior/extrior lights will be a thing of the past.
Cheers.
wraith
Hand over the dog bikkies
Demonicaland
VX V6 Berlina. 2003 VW Passat
Capacitors are a gimmick. Upgrade the big 3 check your earth and go from there.
Cameron P
Quakers Hill, NSW
REDHOT VX SS
Alright I will search this big 3 thing.
Got 2x option audio pro series subs with 1800 watt each I think and I big amp powering those and I got 4 350watt pioneer speakers running off another Amp with 1800+watt and a kenwood headdeck :)
Brenah
Manly, NSW
VZ Exec Wagon
Yeah bud check out the Big3 on You Tube.
The Big3 is what most should be doing to there system b4 going big, and reading your system your getting there.
My 2c
Brendan
VKCOMMO
Carpark Mechanic.....
Springwood, NSW
Cam, ive just done a ground upgrade (2 more 4awg grounds) and it makes a big difference, So yeah, try the big three, and if that doesnt help then we can talk about an optima at the next cruise if you want?
Cameron P
Quakers Hill, NSW
REDHOT VX SS
And cheers Brendan.. It is getting there, after I fix the dimming and make everything all neat and tidy it will be done
Makes me cringe when it's turned up as loud as it can go =P
acarmody
Donati..Whoa Green
VX Berlina
How much did the big 3 cost jack? To do yourself?
Cheers man
4AWG, $10. A few lugs, $10 more. Plus some soldier and a blowtorch, or a big crimper, equals cheap as piss.
