Go to Repco or super **** and find some brake clamps and just chuck them on your rear brake lines. Its cheaper and you cant get defected unless you drive down the road with them on.
Lol dude those calipers are 27 years old. That car is a shell and we have just sarted rebuilding it from scratch.
You asked what brake clamps were, I assumed you had limited mechanical experience. Sorry about that. Are you line locking that car? you might as well put proper ones in if thats the case
Yeap this will be a burnout car, line lockers all the way. I'm assuming for a burnout car you put huge front brakes? Also would we tune the engine to say higher RPMs at lower gears? So longer changes? Yeah that's cool mate, I'm actually studying automotive engineering at the moment.
I was looking at line lockers as well. Reason being, why stuff up my daily ride. Rather disable the rear brakes so that i dont ruin them. Mind you, atmo its only a dream anyway
Same almost finished my second year. It its just a burnout car just block off the rear brake permanently.
Yeah I only started about 3 weeks ago haha. Yeah that's why me and my mates are building this burnout car. To keep our licenses by not doing on road burnouts. Have somewhere safe to do it. And try and show other 18 year olds. It is possible to do without sneaking away at night and shitting about cops, trying to set a good example. Plus mad fun doing it. And all the pride once it's done. Good hobby. I also have a GPS in my glove box (can't have them on P plates in Victoria), just so that when I speed it beeps at me. I already burnt throug one clutch doing burnouts. And put me out of a car and almost lost my job back then. So yeah, no more money on daily car. Any how rant over.
You guy's might find some of this interesting: http://forums.justcommodores.com.au/v6-development-modification/78409-line-locker-setup-abs.html (Using the ABS solenoids to implement a line lock.) I don't have the car to try it (with ABS and cheap parts replacement if it all goes wrong) so haven't done it (yet) but I still think it's a good idea. Some corrections though: VR and VS are still 3 channel, VT- are 4 channnel. There are separate valves for dump and hold in VS and I am pretty sure also for VT-. I would use an Arduino for control rather than a motor speed controller if doing it today. I would still measure and emulate the output signals using that. You can't do "roll control" i.e. lock the brakes on because there are one way release valves in the the blocking solenoid valves that release brake pressure from the wheel cylinders when pedal pressure is released, regardless of valve position. I'd check the temperature of the solenoid valves if left powered for longer than an ABS stop. I think they'll be OK because the initial current spike is much higher than the hold current. In addition to a line lock, you could actuate the solenoids for the front wheels and create a foot operated "handbrake" for handbrake turns (motorkhana). You could also use that while braking and alter brake balance - with care; you could make big changes. If you have a VT- and 4 cahnnel you could emulate an LSD with speed measurement across the diff..
As of yet I would be too afraid to play around with ABS. Secondly I don't even know what computer is attaching to the LS1 going into the burnout car. I'm just new.
I'm 60 and I wish we had them when we were in our younger days instead of lockable vice grips. Having said that there many users for this application the most import is pre race burn out especially if your boost is nitrous plus with all the tech in real street race cars (button & switchers) you don't want to be setting them of for a quick burn out the line lock is much simpler. When you start building high performance street or track cars you'll understand.
No worries I was just looking to find out what people had to say. Not having a lot of money I like to read and and get opinions on anything I do. There is a universe where I agree with you to a point that is if your car can't spin the tyres with straight acceleration it is pretty dismal. But I stand by my original comment.
