Little Help Please
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by vt_ss_5l, Nov 19, 2007.
  1. vt_ss_5l
    vt_ss_5l Banned
    Northen Subs Melbourne
    Vx SS Gen III
    Ok i have a Vn Wagon That im fixing for my sister The Fuel pump Was playing up and Simtimes you Had to Give it a Light Thump to get it started ... Ok So i pulled That Pump out And Replaced it with a New Pump and Still no priming at The Pump so i pulled That One out and tested it with a 12 volt Battery spun up fine so then Put it back in again and still no go .... ?????
    Also have Checked the Fuses & All The Relays Ect
    Pulled The fuel pump Power connector off the rear off The Pump and Checked if its getting Power with a Multi Meter Reading Was in 11's so she has Power The There..
    do you think The Earth Wire on the Fuel Sender is Faulty Or Something ? :bang:
    Any Help Would be Nice Cheers!
  2. Emackulation
    Emackulation Banned
    SE Queensland
    '92 HSV VP GTS
    You have posted in the my ride section, aka the wrong section.
  3. vy_storm
    vy_storm just another moderator... Staff Member
    the burbs of Adelaide
    VE Calais V 6L
    Thread moved.
  4. Morton
    Morton For external use only
    Fairstar the Funship
    Try checking all wires leading to the fuses and relays under the hood. I had a rusty power wire leading to the fuel pump fuse under the hood. Foul connection, and was causing intermittent failure.
  5. vt_ss_5l
    vt_ss_5l Banned
    Vx SS Gen III
    All Fixed it was The Fuel Sender unit it's self There Was a Little Earth Wire Thats Burnt Out The Pump was Fine !
