location of abs fuse
Discussion in 'VE Holden Commodore (2006 - 2013)' started by huthy14, May 7, 2013.
  1. huthy14
    huthy14 New Member
    Canberra Act
    ve ss
    Can someone tell me where the abs fuse is. I have a fault with lost communication with abs module
  2. RiCeY
    RiCeY F O R U M W A R R I O R
    Australia
    VZ SV8 6spd 6.0 470rwhp
    Is the code present or history? If history dont worry about it.
  3. huthy14
    huthy14 New Member
    Canberra Act
    ve ss
    Present. Was playing with steering angle sensor plug and two wires must of come in contact
  4. huthy14
    huthy14 New Member
    Canberra Act
    ve ss
    Is it bad Ricey it's saying contact dealer. Have I done something potentially expensive to fix
  5. RiCeY
    Australia
    What are the codes that are logged history and present?
  6. huthy14
    huthy14 New Member
    Canberra Act
    ve ss
    U0121. Could u tell me where the abs fuse is?
  7. RiCeY
    Australia
    Should be under the bonnet
  8. RiCeY
    Australia
    What were you doing to steering angle sensor connector?
    Which wires touched? (colours)
  9. huthy14
    huthy14 New Member
    Canberra Act
    ve ss
    You wouldn't happen to know what other fuses I could have blown abs fuse is fine
  10. huthy14
    huthy14 New Member
    Canberra Act
    ve ss
    I found the fuse. Thanku though
  11. TONNER_JEZ
    TONNER_JEZ Member
    camden,nsw
    VE SV6 UTE
    i had this and another
    u0415
    got it cleared but what is the description of these codes
    obviously something needs attention or they will just return
