Loom connector identification
maldotcom2
Cammed mafless VS Calais 5-speed.
Got a wiring loom here, just puzzled about some of the connectors.
Now i think A is reverse lights and E is vehicle speed sensor. No idea on the others. Maybe starter motor?
Any help?
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
looks a hell of a lot like the vr auto wiring i was messing with on the weekend D is all the shift solinoids connector on the auto i worked on
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
the VSS is definatly manual "E" does "B" have four round plugs in it with only 3 wires connected
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
allso the vr had the O2 sensor wiring on the same harness so thats one of those plugs too.i talked to my mate about his manual conversion he can sort you out with the stock VS ecu you just need to runn the VSS wire to the ecu and sort the reverse lights
maldotcom2
Well basically what it boils down to is there's nowhere on the gearbox to plug D, so no idea what that is.
Are you saying i could cut off E plug and just run that to the ECU independently and then wire the reverse lights independently?
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
yeah D will be just be hanging there empty for manual its the shift solinoid feed to ecu. E requires switched ignition power and earth and the purple is pulses to ecu you can get the switched power from the stock VS loom from the auto solinoid power feed which is switched with ignition on.then you only need to find an earth in the harness or earth the black sendor wire to the box and run the purple wire to the ecu. reverse lights just need to run up into the interior where the auto shifter wires are so you can attach to the old wires off the auto shift
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
yip theres a second pin on the ecu for manual VSS input
