Lose of power, using to much fuel
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by 4KRUSN, Jul 15, 2012.
  1. 4KRUSN
    4KRUSN New Member
    dubbo
    holden vs ss
    Hey every one i need help with a frustrating issue, i have a vs caprice that has brand new alternator, battery an all wires replaced and is still losing power and sits on bout 10 volts at idle and only goes up wen reved and us using alot of fuel since this started happening.. Have also replaced coolent temp senders.. I took the car to a local performance shop and they said it is doing something funny but cant work out wat
    Any kind of help would be muchly appreciated
  2. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
  3. Aussievtv8
    Aussievtv8 New Member
    Werribee
    Vt ss HOLDEN 304
    6 or an 8?
  4. 4KRUSN
    4KRUSN New Member
    dubbo
    holden vs ss
    V8..
    Its got 180 thousand kms, car is stock standard only parts changed are the new alternator and battery, it all started after the electric thermo stopped workin and could not get it workin again, its had a conputer put on it to check codes an everything was fine but the bloke it is doing something odd and using alot of fuel but they dont no why
  5. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    When you say electric thermo, do you mean the A/C thermo fan in front of the radiator or have you had thermos installed to replace the clutch fan? If it's the A/C thermo then you should disconnect it to see if that makes a difference - you may be getting some sort of voltage/current loss there. There is a connector on the front at the driver's side about half way between the radiator and the guard that you can use to disable the thermo fan. Failing that you should take your car to an auto electrician.
