Yesterday I managed to get the bike frame stripped. I had to use three different methods. First I wire-wheeled all I could. Then I used up some old paint stripper to remove paint from the hard to reach places. Finally I sandblasted the frame. Reason I had to use all three methods was because I only had about 6-7kg of sand. I actually had just enough to finish the job, thankfully. For a moment there I was thinking I would need to head up the road and dig some sand and dry it in the oven.
I ended up painting it with an epoxy enamel from SCA. I added two or three capfuls of hardener to about 350mls of paint just to help it set quicker. Been fortunate that today is about 22deg so the shed was nice and warm when I applied it. Think the skylights helped warm the shed too, which is good.
The paint is dry already but it will take another week before I can start assembling the bike as it take that long to fully cure. I have a lot to work on over the next month. Fortunately I have two weeks leave in mid Jan where I should be able to get it mostly finished. I still have some minor painting to do on a couple of parts. I also need to tear down the brakes and clean them, as the rears were actually beginning to seize.
I also need to repaint the seat as I used acrylic and while it has last 20 years I'd like to freshen it up with hopefully some epoxy enamel.
