Looks like your windscreen is starting to delaminate.I'm pretty sure it's between the seal and glass. The seal has not done its job. It happens a bit on the VE. It's not hugely common but it happens to others as well.
I can go back and find out. I should be able to claim a replacement if that is the case. But he never mentioned it yesterday and said that I would get my claim knocked back until it has a crack.Looks like your windscreen is starting to delaminate.
No buffing will fix that... Your windscreen has probably been replaced before, using el cheapo glass.
You wouldn’t recall the hard water etching on the VE Calais windscreen but it was full on. As in made seeing difficult. Only took a 0000 steel wool and then 5 or 6 treatments with Maguiars Glass Cleaner and a DA. Came up mint though.I went to Instant Windscreens today to have my windscreen assessed. It has a few small chips from a spray of stones a few months ago. They said it's not bad enough and won't develop cracks from the chips. They basically won't support a claim and it would get rejected by my insurer. Sucks because mine has the classic common VE dirty water marks all along the top of the seal.
