losh1971
- Jan 17, 2010
- 22,623
- 22,431
- 113
- Location
- North Tas
- VE Series I SS Ute
All clean, not quite as clean as yours Woteva but pretty damn close. Cleaned te TB as that was black. Cleaned the intake elbow and squirted TB cleaner inside the manifold. That came up pretty reasonable. Its pretty much all back together now. I ended up squirting a bit of RTV on the rubber gasket in the corners as i reckon that is where it was leaking from. All went back together fairly easily. I did squirt some RP7 on the gaskets as was mentioned in the other thread. Good thing too because i needed to slide it around to get the bolts in. Had two hiccups. One of the bolts holding the cruise control bracket snapped off. Don't know why because i only use a 1/4 ratchet and hardly tightend it. Tried getting it out with torx and easy out with no luck. Ended up drilling it out best i could and then filled the hole with JB weld. Then screwed a fine thread tek screw in it. Should be fine because of all the other bolts. Moment of truth was starting tbe engine. Took a bit longer to fire and was running rough for about 10 seconds, but then ran beautiful. I can't be certain just yet as i have only just gone to the post office to collect my drive belt and haven't run the engine up to temp but i think the engine is a lot quieter. Not sure why that would be.
