Spent the arvo and early evening today overhauling my rear brakes on the ute. Fitted new DBA street rotors QFM HPX pads, rebuilt the calipers and fitted two of the three rear braided lines and new shoes. I found one of the slide pins was seized so i had heat it with the Map torch to get it out. All good now plenty of slide grease so it shouldn't get stuck.
Right now i am just waiting for the brakes to cool down before I head down the road to complete the bedding in.
I found out i have leaking axle seal on the drivers side, so I haven't fitted the shoes on that side. I gave them a fair amount of adjustment so they are grabbing when the leaver is pulled. I reckon I won't have a go at the bearing and seal myself as it's a bit of mucking around and I would need some tooling for the press to get the new bearing and retainer on. Hoping that a mech can do the job in 2 hours or less so it doesn't cost me too much.
I am suspecting that the woosh noise i hear from my diff may disappear once the bearing is replaced too.
I would have liked to have fitted the middle braided line this eve but it's too dark and i don't want to get part way through and not be able to lock the shed because the ute is sticking through the entrance. I will aim to get it done in the morning.
As for the brakes they were ok before but I can feel a fair improvement with moderate pedal. I think with all the braids fitted and the bedding in finished i will have substantially better brakes. I'm keen now to ditch the Bosch front rotors i have and fit the new slotteds. But i don't have a set of pads so that will happen in te next few months i suspect. I haven't checked the front pads yet but i reckon they must be getting close to needing replacement.
