losh1971
- Jan 17, 2010
- 22,590
- 22,327
- 113
- Location
- North Tas
- VE Series I SS Ute
yeah replaced the stalk when i fitted the new steering column. Cruise switch even turns off now and it also no longer cuts in at random times while cruising at 100 clicks. On another note i just did some running of the cables for the driving lights. Put main power to the relay, with the fuse left out. Also ran the main power wires to the ballasts. Ballast cover is damaged on one so need to put some black rtv on it to seal it up. Then i will mount them in the lower bumper vent out of the way. Gonna need some help connecting the rest of the relay and tapping in to the high beam as im a bit lost now and Google wasnt much help just confused me. Last time I installed them a mate helped with connecting the switch to the relay. I also had easy access to the high beam as i fitted a HD loom so i could run 100/130 H4 globes and the relay was close by.Maybe I missed it, blinkers working ok?
