lost 3rd and 4 th gear - error 36-
Muik
Yarra Valley
VR Executive Series 2
yesterday my vr series 2 lost 3 and 4 th gear got home checked fluid levels, all ok, ran a code check and it came up with 36 - vaccum leak-, would this error cause the car to go into limp mode? Or is there going to be a bigger underlying problem?
Thanks for any help
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
If you've also lost reverse the fault will be a busted sun shell in the auto which is very common. Otherwise I'd reset the ECU by pulling the engine fuse for 10 secs and the drive the car and read the codes again.
Re the code 36 - can't help you as to whether it will make the car go to LHM ....maybe if it senses no vacuum it figures that you have no power assistance for the brakes and goes to LHM. Hope this is of some help.
Good Luck.
Muik
Yarra Valley
still got reverse, starting to think the 3rd and 4th clutch has burnt out, any way too check this?
Chris E
Vr Executive 3.8
Code 36 won't make your car go in to limp mode, I've had this code since I got the car and the only noticeable ill affect (I think) is a unhappy idle and **** fuel economy. I don't know much about auto's except what I've learnt through mine stuffing up but yeah do what the other fellas said unhook the battery for ten minutes then go for a drive for a few minutes (5-10) and the computer should log new codes that might shed some light.
Muik
Yarra Valley
fixed vacuum problem still havnt got 3rd and 4th reckon the clutch is gone on them gears, so time for a new tranny
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
Read the codes again! - with a bit of luck it will come up with 81 or 82 one of which is shift solenoids in the trans - these will cause it to go to LHM ...a lot cheaper than a reco.
Troy5L
building a lemon
33
Mornington peninsula
Gu patrol td42
isnt limp mode when the gearbox just drives in 4th, and doesnt use the 1st, 2nd and 3rd gears....maybe just try and find a cheep second hand one, a mate said he got one from a wreckers for $70
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
In limp home mode the box stays in 3rd...that means it starts and stays in 3rd - drives like its using an elastic band instead of a motor.
However, you can still manually select the other gears.
You might be lucky and pickup a cheap secondhand box but you generally get what you pay for and it's a lot of work wasted just changing the boxes over I reckon.
Chris E
Vr Executive 3.8
If you treat your gearbox well (IE don't thrash it) and can do the swap yourself I would go for a wreckers gearbox, its luck of the draw but I'd rather fork out $385 for a gearbox with three months warranty before spending 1500-2000 on a reco/new one.
vsiicalais
Donating Member
Wonthaggi
MY15 VF SV6 Storm
your right there, my car went into LHM the other week when the alternator packed it in so i had next to no power to keep the car running. I had to drive about 2 km to get home in LHM but even the cyclists on the orad were going faster then me. Glad i didnt have to take off up any hills cause i dont think i could of made it :whistling
