lost
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by glowworm, Apr 8, 2007.
  1. glowworm
    glowworm Member
    vt exective
    :bang: can someone please tell me where the FUEL PREASURE REGULATOR is on a vt v6 thanks
  2. 1vngal
    1vngal New Member
    North Tassie
    'Ruby' 1991 VN Exec & '98 Proton M21 Coupe
    The fuel pressure regulator is located to the rear of your engine bay on the left hand side, it's connected to the end of the fuel rail. :)
  3. glowworm
    glowworm Member
    vt exective
    thanks for that..
  4. glowworm
    glowworm Member
    vt exective
    hmmmm
    :bang:
    So you are saying if the F.P.R is stuffed i have to repace the fuel rail as well as it is all one peace..
  5. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    The FPR can be replaced. That part on the fuel rail has the regulator inside, so you can pull that apart and get the regulator out.
  6. glowworm
    glowworm Member
    vt exective
    Please explain as it looks to me that FPR is all one peace i dont understand how you could get it apart ..thanks
  7. 1vngal
    1vngal New Member
    North Tassie
    Sorry, I didn't mean it sound as though it was one piece. I just used the fuel rail as a guide to where it was. :)
    And to get it off, first, reduce the fuel system pressure and disconnect your negative battery terminal.
    Then, remove your engine cover, then take off the fuel rail. Next, remove the snap ring thingy that that holds the FPR to the fuel rail, then you have to sorta twist the FPR to get it off.
  8. 1vngal
    1vngal New Member
    North Tassie
    Oh, and cover then end of your fuel rail where you took the FPR off, just with a bit off sticky tape or something, just to stop and dirt or crap getting in there while you have the FPR off.
  9. glowworm
    glowworm Member
    vt exective
    hmmm
    On a vt the fuel line and F.P.R are one they dont come apart no screws no o rings no nuts if you take fuel rail off the FPR comes with it i know on the vn it comes apart but not on the vts..
  10. 1vngal
    1vngal New Member
    North Tassie
    I think the regulator is inside that metal housing, once you remove the snap ring, it should just come out of the housing.
  11. accentstencil
    Eschol Park, Sydney
    Exactly....
  12. glowworm
    glowworm Member
    vt exective
    Hey thanks for that now see i was thinking it was all one peace once again i thank you for your help
  13. glowworm
    glowworm Member
    vt exective
    do you have any other reasons why i have trouble starting my car in the mornings or sitting all night we have the fuel pressure valve any others,,please.
