Loud screaching when turning left ?
vsl67
VS l67 statesman
I have a vl that has a lound screaching sound when turning left,not sure but I think its coming for back left brakes or maynot anyone got any suggestions ?
vsl67
VS l67 statesman
I checked it the level seems fine but the colour is not so good its black, I just got the car today
social
Ute Finatic
South Aus
2012 VE Thunder
check your front rubber bushes, your power steering rack under the car for starters
jatsvl
NEEDS MORE POWER!
vl exec wagon
maybe check rear left wheel bearing. and diff oil.
fuzzy2308
Plastic datsun
stop doing hand brakies LOL. check ya rubber do hickie under ya var
harry3
71
vl berlina wagon 6cyl
drain power steering fluid and replace, its self bleeding
while under car their should be a plastic tube to equalise air pressure in the rack, this is often knocked off by bush bashing and if missing will cause problems eventually
vsl67
VS l67 statesman
ok I will check and drain fluid etc, but come to think of I bought it of my friend who is 83 and he always like spinning the wheels so it wouldnt surprise me if he did hand brakeys
detox_nath83
Another VL Driver
37
Queensland(Sunny Coast)
VL Turbo Commo
So Grandpa is a Hoon :p
Mine has a loud screaching sound when i full lock either way but its coming from the belt on the powersteeing pump as it gains a load at full lock :p
vsl67
VS l67 statesman
yer it sounds like metal on metal though, but I dont touch the brakes or can find anything rubbing ,but the rear pads do look a little low
