Low Beam Off When High Beam On?
Ozzie
JCCC Warrnambool
Warrnambool
Ozzie'z Supercharged VY Calais
Hi all.
I have a problem and can not seem to find an answer anywhere,
I have installed VT altezza headlights. Low beam is H1 - High beam is H1.
Ive recently installed a H1 HID Low Beam Kit and since the kit has been installed ive had this problem.
The problem is that when low beam is on both low beams work.
When I switch to high beam only the drivers side low beam is working.
Both sides of high beam still work,
Any ideas? Ive checked fuses and wiring and all seem to be fine.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
A bad contact on the relay?
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Did you bump the relay block at all? Could have knocked it loose.
Ozzie
JCCC Warrnambool
Warrnambool
Thats possible... I had to change the headlight fuses cous they blew.
But it was pretty dam tight in there, Contacts were corroded a bit though so that could have been the problem to start with?
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Possibly. It works now so it's all good.
