Low beams not working all of a sudden - high and park fine
lkorruptl
Hello,
hope you can help. The low beams on my VY commodore have just decided to simoultaneously not work.
I have checked the fuses and relays (swapped with horn) and they are all fine. Park lights and high beam still work fine. The switch I believe is fine as I hear a clicking in the relays when the switch is turned to on.
I fiddled with the wiring (which I assume must be the problem) and the left park light stopped working for a few minutes too. This leads me to believe its definately the wiring, however where on earth do I start to troubleshoot where the fault could be?
Any suggestions or alternatives to what the problem could be?
Thanks in advance.
danieLOL
VY Executive S2
open the screw plastic thing behind the bulb and play around with the bulb, mine sometimes loses contact cause its a bit loose so that could be a reason
lkorruptl
Thanks Daniel,
have tried that too... Think there is a problem with the wiring between the relay and before it splits into left and right headlight...
lkorruptl
Not 100% sure but they are the standard aftermarket replacements... have been using them for more than a year with no problems!
lkorruptl
Thanks for your reply. Im not sure as I don't have a multimeter, however I would assume that there is no voltage running from the relay through the low beam circuit to the lights. There is only one connector socket per side which operates low beam, high beam and parking lights so there must be some volatge coming through as the parks and highs still work fine. Have unbolted the fuse box, but because the cables are so tight I can't move it more than a few inches, and thus its very difficult to actually trace the wiring from the low beam relay to the light sockets to see if there is any breaks in there... Can you suggest anything to solve this problem?
lkorruptl
Any more suggestions please? It is quite irritating as I can't drive at night now :(
DLFHUB666
GIT 'EERRR DONE!!!
Nhulunbuy NT
VX SS, PX Ford Ranger XLS Dual cab
have you tried changing the bulbs?, that would have been my first step.
