Low compression 50psi
J
Joes_meat
Guest
I've just had a look at a mates car.
He was complaining about missfiring at low-revs (seems fine at 1200rpm.)
I had suspected the coil-pack or DFI module.
But I first did a compression test. An even 125psi on all cylinders except cylinder 3.
It showed 50psi dry and 80psi wet.
I'm just trying to work out what the most likley cause for this is?
Broken piston ring/bent valve/broken or stuck valve seat?
Thanks in advance.
Morgasshk
Morgasshk
42
www.personaltradingpost.com.au
VY Exec 3.8L Sedan 9C1 Pack
blown rings...
maginoodle
vy series2 ss crewman
Thanks in advance.
are the 3 cylinders on the same bank? if so it could be a bad head or head gasket, if they are on different banks i would say rings need replacing.
FXST01
The Grey Man
Perth, WA
VP V6 Exec
Not 3 cylinders, cylinder number 3. Could be either your rings or a burnt or leaky valve. A vacuum gauge should point you in the right direction.
mouce
Physics Geek
39
VN V6 Series 1 Executive Sedan
Cracked piston? I've heard of it happening.
commy92
VP WAGON V6
could be so many things. In reality either way its going to have to be stripped ide say to solve the problem, I think that this is whats wrong with mine, a rooted ring or piston. Im to afraid to compression test it.
J
Joes_meat
Guest
I'll see if I can get a vaccum test. If it's a valve problem, I'll fix it, if it's a ring problem I got a quote for $880 for a low-km motor with warranty (full engine barring alternator.)
How would I go about a vaccum test and how would I understand the results?
Tree cutter
Tree cutter
Mt Gambier SA
VX Calais SuperchargedV6
If it is a piston or ring problem it would blow a fair bit of smoke when you give it a good rev. More than likely a valve or valve seat problem.
J
Joes_meat
Guest
Thanks for the help guys, I'll let you know how it turns out.
