Low speed fan issue, AC middle vents no working.
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by GTP 85, Feb 28, 2012.
  1. GTP 85
    GTP 85 291 hp @ the wheels
    Murray Bridge S.A
    MY04 WRX, VS SSenator & VS V6 track weapon
    Had my ac regassed on my VT 5L.
    The repairer said that the low speed fan that runs through the condenser isnt working? checked the relays and they are fine.. any ideas???
    Also the center vents arent blowing air on any mode? It seems to only be blowing air through the dash/ windscreen vent across the front.
    Got me stumped! anyone got some trouble shooting ideas?
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    Start by checking that the thin vacuum hose is connected at the rear of the intake manifold and is a tight fit.
    As far as I know there is no low speed fan, both fans operate on low and high speeds. If one of your fans is not working, connect 12 volts directly to the terminal and see if it works or not, to eliminate a faulty fan.
  3. 50LTRv8
    50LTRv8 Member
    VT V8 Calais
  4. GTP 85
    Murray Bridge S.A
    its a vt calais S1 v8. Has the dual zone climate.
    I mine check the vacuum hoses on the back of the engine, coz i did recently adjust the dissy.
    Thanks for the links 50LTRv8
