Vin999
I think from memory the last digits of the stand shock is 0565...so yours could be the shortened ones for the ultra low springs, I will check my vl paperwork on parts later and report back, you could google your number and find out in the meantime.Curerntly the monroe gt sport shocks i have are part #15-0567.
On the king springs website it lists the KHRL-20HD as a Lowered EHD spring for my 1988 holden commdore vl 3.0L sedan as a stiffer spring so hopefully that can should fix my problems.
Thinking about it, are my shocks even a shortened shock and are they the right shocks for my springs? or are there another monroe shock better suited?
EHD is for carrying more weight and springs might be thicker with revised coil rates.
Vl's had problems with lowered springs falling out using standard height shockers thus the recommendation for shorter shocks, this mostly happened with the ultra lows........ some people with this issue just bought a 10mm nolathane spring base to avoid spring this.
