Lowering and exhaust.
PooksVT97
Launceston
Holden commodore VY SV8
Im new with this site, just wanted to ask a few questions...
I have bought springs too lower my commodore, can i install them without doing anything else.?
and should i put an exhaust on for bit more sound or a tip? and will it affect my engine??
GothicKidd
ლ(ಠ益ಠლ
South Australia
VR S2 Exec
My understanding is.. If you want to lower a car... you have to get a wheel balance/alignment after
Exhaust should help your engine... having a exhaust tip wont do anything apart from look good..
Jezza
Now with LS1 power
South Australia
WH Statesman International
yes you can put the springs in without doing anything else but if the shocks and struts are original then they may need replacing (just lowered mine last week and the car had done 191,000km on the original spring and needed replacing badly which i did)
as for the exhaust all it will do is give it a tiny bit more power and make it louder and if your car is a auto then i would recommend a tip because it will reduce the drone that a larger exhaust causes
