Lowering Motorsport/Directors
Discussion in 'VF Holden Commodore (2013 - 2017)' started by jcwdrive11, Apr 12, 2018.
  1. jcwdrive11
    jcwdrive11 New Member
    VE SS
    I understand this topic has been discussed before but has anyone had any luck lowering their Motorsport/director? Walkinshaw refuse to lower them as they believe it affects the MRC. Could go elsewhere but don't want to void my warranty. Thoughts?
  2. EternityDre
    EternityDre Well-Known Member
    Melbourne, Victoria
    MSE #385
    There are at least 2-3 people who have done it and posted about it in the limited editions thread. One of them should pop up and post details, you could try the search function in the meantime.
  3. monstar
    monstar Naturally as-pirated
    depths of Hays Inlet
    Peugeot 207 GTi
    What do you mean could go somewhere other than Walkinshaw? They are not Holden, nothing to do with your car actually. Whatever BS they fed you about your warranty is just that. Shop around FFS.
  4. Sean880
    Sean880 Well-Known Member
    VIC / NSW
    2012 VE SV6 ser 2 and 911 Porsche Carrera S 997
    You don't void your Manufacturer warranty on the entire vehicle by making an unapproved modification to the vehicle. What you do is to limit your warranty cover on any component that fails or is damaged as a consequence of you making that modification.
    Read the terms of your Holden warranty you will find in the service book. It includes a statement along these lines...............
    " The Voluntary warranty does not cover damage caused by :
    (e) alteration or modifications of the vehicle by anyone not authorised by Holden
    (f) fitting of parts or accessories not recommended by Holden."
    The operative and critical words here being "does not cover damage caused by ".
    Since you have paid a lot of money for the MRC damper system I would be cautious.
    In the US, Eibach has developed a lowered spring specifically for a MRC equipped Camaro SS which drops the vehicle a fraction over 1 inch. They also have lowered spring kits for Camaros without the MRC option, ie cars fitted with the standard shocks and struts. These lesser kits are definitely not designed for MRC vehicles.
    GM has done the same. They offer upgraded suspension packs with lowered springs you can buy off the shelf for your Camaro with the standard suspension but these are not designed for the MRC cars. They have a separate retail suspension package specifically designed for the MRC cars which includes upgraded springs designed to work with the MRC but I don't know if it is actually a lower spring.
    Eibach offers springs kits here in OZ specifically for VE and VF commodores but from what I have seen these are specifically denoted as applicable only for standard suspension commodores - not MRC equipped cars. So I would check with them to see if they have anything they could offer you for your MRC equipped car and what comments they have on fitting one of their non MRC lowered spring kits to an MRC equipped commodore.
    I assume the ECU for the MRC system has been calibrated based on the amount of suspension travel allowed with the stock spring as well as the spring rate. How that electronic system system then reacts when you put in a lower spring which typically will also have a higher spring rate, and when the piston in the dampers will sit in a different position from stock, I guess is one of the questions.
    As for Walkinshaw, at one stage they had a lowering kit for VE series HSV vehicles they claimed worked with MRC equipped HSVs entitled - " WP MRC Suspension lowering Kit ". Looks like nothing like this is currently offered any longer - just spring kits for vehicles without the MRC suspension.
    monstar likes this.
  5. HemiMagic
    HemiMagic Active Member
    Queensland
    VF SSV REDLINE, CL Charger, VK Charger, Motorsport
    Leave it alone..............
  6. [paradox]
    [paradox] Member
    VF2 SSV-R
    plenty of the chevy SS guys lower with MRC. you just need to reset it after installing the springs.
    monstar likes this.
  7. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    VF Redline Sedan - A6 Spitfire MSE...
    I'll be going for a test drive in a mate's lowered Director before I do anything with mine. It's only aesthetics really. The handling and ride is great in standard form.
    PSISLE likes this.
  8. Bren66
    Bren66 New Member
    Camden
    Vf Motorsport
    +1 for that. MRC works great, wouldn't want to screw it up for a slightly lower look and they don't look that bad with the 20's. Gona leave mine as it is.
    426Cuda likes this.
  9. DIR115
    DIR115 New Member
    Calais Director
    Horse Power Factory located in Dandenong say they have a lowering option for VF GTS with MRC and don't see it being an issue to fit to the Calais Director. The springs lower a GTS around 20mm, They don't have heights for Director but they feel safe to assume it would lower it by at least that amount.
  10. PSISLE
    PSISLE Well-Known Member
    Radelaide
    VH SL/E, VY2 l67 calais, ve2 l77 Calaisv wagz
    Good idea, use him as the guinea pig lol
    426Cuda likes this.
  11. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    My thoughts Ed Zachary!
    PSISLE likes this.
  12. arthurk
    arthurk Member
    SSV Redline VFII / SSV Motorsport KOM0993
    HSV and LE MRC are different I believe so anyone telling you they can do it needs to be careful. I could be totally wrong. As stated above look at ssforums.com and what the guys are doing. From all my reading over there they are sourcing springs from Australia.
    426Cuda likes this.
  13. dimetime
    dimetime Active Member
    ve calais 6lt
    am i crazy in thinking the mrc is only your shock hardening and softening depending on your setting, pretty sure kingsprings have a mrc spring that will lower the car and not effect your mrc from functioning, as for your warranty, as far as i know holden would have to prove that your spring was the reason for whatever might break?
  14. [paradox]
    [paradox] Member
    VF2 SSV-R
    correct
    mrc specific springs are for hsv, not le
    PSISLE likes this.
