Lowering vs Ute
brockkkk
24
Newcastle
Vs Ute
Hi I’ve got a vs Ute 5L I’ve lowered it on supers in the front and ultras in the back and it’s still sitting higher than what I want, the front looks good but the rear still sits high. How do I go about getting it a bit lower. Do they make springs lower than ultra lows? I don’t want to cut them and make it ride any worse than it does, I have all lowered shocks and all thanks.
gossie
Gold Coast.
VE International 3.6L
Is it well above 100mm off the ground?
If you put something in the tub that will lower it and make it unroadworthy if play anymore with it v
woteva
NEED 4 SPEED
Adelaide S.A.
Add half a dozen bags of concrete mix to the rear tray
losh1971
North Tas
VE Series I SS Ute
Only need 2 bags in a Commodore tub ute if you place them behind the axle.........
vc commodore
Like the Leyland Brothers
VC, VH and VY
Hint...Lowering it more will make it ride worse....So you can't have your cake and eat it too
woteva
NEED 4 SPEED
Adelaide S.A.
It won't go any lower once you are on the bump-stops.
gtrboyy
vt ss & lc gtr
Raise the front...might look good,shite to drive.
shane_3800
35
places
vr commo
Pedders make a extra low coil where you need shorter shocks. I had to add 10mm upper spacers to gain an extra 10mm in height but looked good.
